メインコンテンツにスキップ
LG CF360 Motherboard Replacement
必要な工具と部品
  1. LG CF360 Motherboard Replacement, Battery: 手順 1、 2の画像 1 LG CF360 Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 Motherboard Replacement: 手順 2、 1の画像 1
    • Lift and remove the battery.
  3. LG CF360 Motherboard Replacement, Back Cover: 手順 3、 2の画像 1 LG CF360 Motherboard Replacement, Back Cover: 手順 3、 2の画像 2
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 Motherboard Replacement: 手順 5、 3の画像 1 LG CF360 Motherboard Replacement: 手順 5、 3の画像 2 LG CF360 Motherboard Replacement: 手順 5、 3の画像 3
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 Motherboard Replacement: 手順 6、 1の画像 1
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
  7. LG CF360 Motherboard Replacement, Motherboard: 手順 7、 2の画像 1 LG CF360 Motherboard Replacement, Motherboard: 手順 7、 2の画像 2
    • Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
    • An orange ribbon from the LCD is connected to the underside of the motherboard, so do not force the motherboard from the rest of the phone yet.
  8. LG CF360 Motherboard Replacement: 手順 8、 1の画像 1
    • Gently remove the blue transparent tape from the connector.
  9. LG CF360 Motherboard Replacement: 手順 9、 1の画像 1
    • With the plastic opening tool, gently pry the LCD connector from the motherboard.
    • Set the motherboard aside.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Aaron
メンバー登録日: 10/15/13
167 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 4-27, Amido Fall 2013 Cal Poly, Team 4-27, Amido Fall 2013人のメンバー
CPSU-AMIDO-F13S4G27
4 メンバー
19のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 968
