必要な工具と部品
Locate the small rounded recess to get access to the battery
Gently, lift the battery
Use a Phillips #00 screw driver to remove six screws.
Run the plastic opening tool along the edge of the phone to release the casing cover.
Lift the casing cover.
Use the plastic opening tool or fingernail to lift the rectangular piece up. The piece can be identified by the orange tape attached to it.
Dislodge the logic board using a plastic opening tool.
Remove the logic board by lifting up.
2 の人々がこのガイドを完成させました。
