危険
潜在的な危険
この手順に正しく従わない場合は損傷が生じる可能性があります。ご注意のうえ使用し、すべての警告に従ってください。
危険
はじめに
Replacing the power supply board inside the LG 32CS560 is a simple task to complete with the proper preparation. It involves opening up the TV, identifying the bad power supply board, removing it, adding a new power supply board, and re-assembling the TV.
Note, only replace the power supply board if you know it is the cause for your TV's problems. If the TV doesn't turn on or only the LED's on the front of the TV turn on, then the power supply is likely to blame. Use the troubleshooting guide to help you determine if you need to replace the power supply board. Also, an annoying wining noise or burn marks on the power supply board indicate it has failed.
Please have a replacement power supply board ready to go as well. The model of power supply is the LGP32-12P. You can purchase it from numerous sites such as eBay here.
  1. Lay the TV face down on a soft surface
    • Lay the TV face down on a soft surface
    • Locate the position of the 15 screws needed to take the TV apart
    • Be sure you already removed the TV's base by unscrewing the 4 base screws.
  2. Use a Phillips head screwdriver to unscrew all 15 screws from the back of the TV Carefully remove the black plastic back panel of the TV to expose the electronics inside
    • Use a Phillips head screwdriver to unscrew all 15 screws from the back of the TV
    • Carefully remove the black plastic back panel of the TV to expose the electronics inside
    • Locate the power supply board in the yellow square. The power supply board is the only board that is not green.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Carefully disconnect the three wire bundles  attached to the bad power supply board. They are in yellow boxes in the picture Remove the four screws (red circles in the picture) in the corners of the bad power supply board and lift it up to remove it The black cylindrical component in the green square on the board is a capacitor. If it is puffy or leaking liquid or goo, then the power supply board is definitely bad!
    • Carefully disconnect the three wire bundles attached to the bad power supply board. They are in yellow boxes in the picture
    • Remove the four screws (red circles in the picture) in the corners of the bad power supply board and lift it up to remove it
    • The black cylindrical component in the green square on the board is a capacitor. If it is puffy or leaking liquid or goo, then the power supply board is definitely bad!
  5. Simply put your new power supply board in place of the old one!
    • Simply put your new power supply board in place of the old one!
まとめ
10 の人々がこのガイドを完成させました。
Coyt Barringer
メンバー登録日: 2014年10月11日
487 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 1-3, Donnelly Fall 2014 USF Tampa, Team 1-3, Donnelly Fall 2014人のメンバー
USFT-DONNELLY-F14S1G3
1 メンバー
1のガイドは作成済み
コメント1件
preciso duma destas power bord como fazer para ter
brun mendes - 返信
統計データを表示:
過去 24時間: 7
過去 7 日: 84
過去 30 日: 326
今までの合計 23,493
