はじめに
This repair guide will instruct the user how to properly remove the back cover on a LG cell phone.
パーツ
パーツは必要ありません。
  1. Turn off the cell phone and place face down on a flat surface.
    • Turn off the cell phone and place face down on a flat surface.
  2. While sliding the gray tab up, lift battery up and away from the cell phone. While sliding the gray tab up, lift battery up and away from the cell phone.
    • While sliding the gray tab up, lift battery up and away from the cell phone.
  3. Remove battery and set aside. Remove battery and set aside. Remove battery and set aside.
    • Remove battery and set aside.
  4. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  5. While holding cell phone firmly in one hand, unscrew and remove the antenna with the other hand.
    • While holding cell phone firmly in one hand, unscrew and remove the antenna with the other hand.
  6. Pull the antenna housing (black tube) towards bottom of phone and remove. Pull the antenna housing (black tube) towards bottom of phone and remove.
    • Pull the antenna housing (black tube) towards bottom of phone and remove.
  7. Unscrew the four screws on the back case using a T6 Torx Screwdriver. Unscrew the four screws on the back case using a T6 Torx Screwdriver.
    • Unscrew the four screws on the back case using a T6 Torx Screwdriver.
  8. Pull the back cover straight off the phone using your thumb and forefinger. Pull the back cover straight off the phone using your thumb and forefinger.
    • Pull the back cover straight off the phone using your thumb and forefinger.
まとめ
ある他の人がこのガイドを完成しました。
Nicholas Schmidt
メンバー登録日: 2010年10月09日
97 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 3-25, Regan Fall 2010 Cal Poly, Team 3-25, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S3G25
4 メンバー
14のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 628
