はじめに
If battery power is draining too quickly, or if it is unable to hold a charge altogether, it's time to replace the battery. The task is simple and straightforward, with minimal tools required. Follow this guide to replace the battery for your Kyocera Zio M6000.
必要な工具と部品
Press down on the back of the phone, applying moderate pressure.
Slide the back casing down to separate it.
ある他の人がこのガイドを完成しました。
