メインコンテンツにスキップ
Kyocera QCP-2035 Microphone Replacement
必要な工具と部品
  1. Kyocera QCP-2035 Microphone Replacement, Remove Back Cover: 手順 1、 3の画像 1 Kyocera QCP-2035 Microphone Replacement, Remove Back Cover: 手順 1、 3の画像 2 Kyocera QCP-2035 Microphone Replacement, Remove Back Cover: 手順 1、 3の画像 3
    • When looking at the back of the phone, you will see a horizontal line and three raised segments of plastic in the form of a triangle.
    • Place thumb on top of the triangle and press into the phone while sliding your thumb towards the bottom of the phone.
    • In 5 mm it will stop sliding.
  2. Kyocera QCP-2035 Microphone Replacement: 手順 2、 3の画像 1 Kyocera QCP-2035 Microphone Replacement: 手順 2、 3の画像 2 Kyocera QCP-2035 Microphone Replacement: 手順 2、 3の画像 3
    • Grab the bottom of the back cover with your other hand and pull the cover the rest of the way off.
    • Turn the phone over slowly. The battery will fall out on its own.
  3. Kyocera QCP-2035 Microphone Replacement: 手順 3、 3の画像 1 Kyocera QCP-2035 Microphone Replacement: 手順 3、 3の画像 2 Kyocera QCP-2035 Microphone Replacement: 手順 3、 3の画像 3
    • Rotate the phone so the bottom is facing you. There is a small indent on the plastic face.
    • Using the tip of your fingernail or a spudger, pry the cover away from the rest of the phone.
    • Once the cover starts to part, keep separating until the top notches detach.
  4. Kyocera QCP-2035 Microphone Replacement: 手順 4、 3の画像 1 Kyocera QCP-2035 Microphone Replacement: 手順 4、 3の画像 2 Kyocera QCP-2035 Microphone Replacement: 手順 4、 3の画像 3
    • With the cover plate separated, you will see (6) T6x11mm torx screws recessed in the white plastic.
    • Remove screws.
    • The white plastic face plate lifts right off, exposing the main board.
  5. Kyocera QCP-2035 Microphone Replacement, Microphone: 手順 5、 3の画像 1 Kyocera QCP-2035 Microphone Replacement, Microphone: 手順 5、 3の画像 2 Kyocera QCP-2035 Microphone Replacement, Microphone: 手順 5、 3の画像 3
    • Locate the microphone at the bottom left corner of the phone.
    • using tweezers, Lift the microphone straight out of the phone.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
cove
メンバー登録日: 01/21/15
116 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 5-3, Brown Winter 2015 USF Tampa, Team 5-3, Brown Winter 2015人のメンバー
USFT-BROWN-W15S5G3
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 223
