メインコンテンツにスキップ
Kyocera Oystr Screen Replacement
必要な工具と部品
  1. Kyocera Oystr Screen Replacement, Removing the battery: 手順 1、 3の画像 1 Kyocera Oystr Screen Replacement, Removing the battery: 手順 1、 3の画像 2 Kyocera Oystr Screen Replacement, Removing the battery: 手順 1、 3の画像 3
    • Make sure the phone is turned off before disassembly.
    • Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing.
    • Remove the battery from the casing. This is simply a precaution.
    • Turn the phone over, so that the front side is facing you. Open the device in preparation for the next step.
  2. Kyocera Oystr Screen Replacement, Removing screws from screen: 手順 2、 3の画像 1 Kyocera Oystr Screen Replacement, Removing screws from screen: 手順 2、 3の画像 2 Kyocera Oystr Screen Replacement, Removing screws from screen: 手順 2、 3の画像 3
    • Peel the Virgin Mobile sticker off of the phone's screen to reveal two screws beneath it.
    • Use the Tri-Wing Y0 screwdriver to remove the two screws from the screen.
  3. Kyocera Oystr Screen Replacement, Exposing internal components: 手順 3、 3の画像 1 Kyocera Oystr Screen Replacement, Exposing internal components: 手順 3、 3の画像 2 Kyocera Oystr Screen Replacement, Exposing internal components: 手順 3、 3の画像 3
    • Lift the plastic cover of the phone screen upwards with a plastic opening tool.
    • Remove the two screws from the metal cover.
  4. Kyocera Oystr Screen Replacement, Removing metal cover: 手順 4、 1の画像 1
    • Remove the metal cover by lifting up and away from the device.
  5. Kyocera Oystr Screen Replacement, Screen removal: 手順 5、 3の画像 1 Kyocera Oystr Screen Replacement, Screen removal: 手順 5、 3の画像 2 Kyocera Oystr Screen Replacement, Screen removal: 手順 5、 3の画像 3
    • Use the plastic opening tool to pry the phone's speakers up and away from the device. These speakers will dangle by the wires attached to the board.
    • Use your fingernail to detach the ribbon connecting the board to the screen.
    • Remove the damaged screen from the device.
  6. Kyocera Oystr Screen Replacement, Completing the repair: 手順 6、 1の画像 1
    • Follow these steps in reverse order to replace Kyocera Oystr’s screen.
終わりに
作成者
9人の作成者と共同で作成されました。
David
メンバー登録日: 10/04/11
24 ポイント
2のガイドは作成済み
チーム
UW Stout, Team 5-7, Zhou Fall 2011 UW Stout, Team 5-7, Zhou Fall 2011人のメンバー
UWSTOUT-ZHOU-F11S5G7
2 メンバー
4のガイドは作成済み
2 件のコメント
My screen goes blank for days, then shows. maybe for minutes of seconds. Do I need to replace the screen, or is there a control I can try to bring back the display? The phone is charged and rings. Yours is a wonderful website. Thank you.
Martha Carnahan mpc@netsync.net
Martha Carnahan - 返信
My screen goes blank for days, then appears, but only for minutes or seconds before it goes blank again. Do I need to replace the screen, or do you know if there a command which would solve the problem? The phone is charged and rings.
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 16
今までの合計 2,216
