メインコンテンツにスキップ
Kyocera Hydro Life Rear-Facing Camera Replacement
必要な工具と部品
  1. Kyocera Hydro Life Rear-Facing Camera Replacement, Rear-Facing Camera: 手順 1、 1の画像 1
    • Flip the phone so that the screen is facing down.
    • Gently remove the back cover with the grip at the bottom of the phone.
  2. Kyocera Hydro Life Rear-Facing Camera Replacement: 手順 2、 3の画像 1 Kyocera Hydro Life Rear-Facing Camera Replacement: 手順 2、 3の画像 2 Kyocera Hydro Life Rear-Facing Camera Replacement: 手順 2、 3の画像 3
    • Use the tab marked "PULL" to remove the battery from its enclosure.
  3. Kyocera Hydro Life Rear-Facing Camera Replacement: 手順 3、 2の画像 1 Kyocera Hydro Life Rear-Facing Camera Replacement: 手順 3、 2の画像 2
    • Remove the six Phillips #00 screws from the back of the enclosure.
    • Use a plastic opening tool to gently remove the plastic piece surrounding the back of the phone enclosure.
  4. Kyocera Hydro Life Rear-Facing Camera Replacement: 手順 4、 1の画像 1
    • Remove the white sticker.
  5. Kyocera Hydro Life Rear-Facing Camera Replacement: 手順 5、 2の画像 1 Kyocera Hydro Life Rear-Facing Camera Replacement: 手順 5、 2の画像 2
    • Using a pair of pliers, gently pry open the camera ribbon slot.
    • This will not take much pressure to open.
  6. Kyocera Hydro Life Rear-Facing Camera Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    購入する
    • Gently remove the camera ribbon.
    • Be very careful not to rip the ribbon. Use tweezers if needed.
  7. Kyocera Hydro Life Rear-Facing Camera Replacement: 手順 7、 2の画像 1 Kyocera Hydro Life Rear-Facing Camera Replacement: 手順 7、 2の画像 2
    • Using a plastic prying tool, gently loosen all 4 corners of the motherboard.
    • Lift the motherboard away from the phone enclosure.
  8. Kyocera Hydro Life Rear-Facing Camera Replacement: 手順 8、 1の画像 1
    • Remove the black sticker.
    • Be careful when removing the sticker. The sticker will need to be replaced after replacing the camera.
  9. Kyocera Hydro Life Rear-Facing Camera Replacement: 手順 9、 1の画像 1
    • Remove the camera from the motherboard.
    • This step requires breaking metal.
    • Only cut along the camera square.
終わりに
作成者
5人の作成者と共同で作成されました。
Morgan Marshall
メンバー登録日: 09/21/18
277 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S2-G6, Riccardelli Fall 2018 University of North Texas, Team S2-G6, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S2G6
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 220
