1. Remove back  cover
    • Remove back cover
    • Pry from the gap above charger port as displayed.
  2. Remove battery
    • Remove battery
    • Use a PH00 screwdriver to remove the 6 screws from the mid-frame.
    • Removing the screws too carelessly can result in them being damaged or stripped.
    • Remove back panel trim
    • Back panel trim is fairly thin, be cautious when removing it.
    • Remove back panel
    • Pry the 4 corners off first
    • Remove power button with tweezers
まとめ
Haley Brown
メンバー登録日: 2018年09月21日
183 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S2-G6, Riccardelli Fall 2018 University of North Texas, Team S2-G6, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S2G6
4 メンバー
7のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 22
過去 30 日: 35
今までの合計 44
