メインコンテンツにスキップ
Kyocera Event Rear Assembly Replacement
必要な工具と部品
  1. Kyocera Event Rear Assembly Replacement, Battery: 手順 1、 3の画像 1 Kyocera Event Rear Assembly Replacement, Battery: 手順 1、 3の画像 2 Kyocera Event Rear Assembly Replacement, Battery: 手順 1、 3の画像 3
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event Rear Assembly Replacement: 手順 2、 1の画像 1
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. Kyocera Event Rear Assembly Replacement, Locate the SIM card: 手順 3、 1の画像 1
    • The SIM card slot can be seen in the middle left of the photograph.
  4. Kyocera Event Rear Assembly Replacement, Open slot and remove card: 手順 4、 2の画像 1 Kyocera Event Rear Assembly Replacement, Open slot and remove card: 手順 4、 2の画像 2
    • The SD card slot can be opened and closed, as depicted by the tool.
    • The SD card itself slides into and out of the metal cover.
    • The gold tipped tines are what read the SD card along its bottom.
  5. Kyocera Event Rear Assembly Replacement, Remove the screws.: 手順 5、 2の画像 1 Kyocera Event Rear Assembly Replacement, Remove the screws.: 手順 5、 2の画像 2
    • Remove seven of the 4.9mm tri-head screws. Keep them in a secure location.
  6. Kyocera Event Rear Assembly Replacement, Remove the back assembly: 手順 6、 3の画像 1 Kyocera Event Rear Assembly Replacement, Remove the back assembly: 手順 6、 3の画像 2 Kyocera Event Rear Assembly Replacement, Remove the back assembly: 手順 6、 3の画像 3
    • Pry the back assembly away from the body on all four sides of the phone.
    • Start prying at the top and work around.
    • Remove the buttons for the volume and power-this will allow for easier disassembly.
    • The back assembly is firmly attached to the body of the phone so removing it will require some force.
終わりに
作成者
10人の作成者と共同で作成されました。
Philip
メンバー登録日: 02/13/15
7 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-4, Michaels Spring 2015 Ohio State, Team 1-4, Michaels Spring 2015人のメンバー
OSU-MICHAELS-S15S1G4
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 795
