メインコンテンツにスキップ
Kyocera Event MicroSD Card Replacement
  1. Kyocera Event MicroSD Card Replacement, Battery: 手順 1、 3の画像 1 Kyocera Event MicroSD Card Replacement, Battery: 手順 1、 3の画像 2 Kyocera Event MicroSD Card Replacement, Battery: 手順 1、 3の画像 3
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event MicroSD Card Replacement: 手順 2、 1の画像 1
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. Kyocera Event MicroSD Card Replacement, Locate the SIM card: 手順 3、 1の画像 1
    • The SIM card slot can be seen in the middle left of the photograph.
  4. Kyocera Event MicroSD Card Replacement, Open slot and remove card: 手順 4、 2の画像 1 Kyocera Event MicroSD Card Replacement, Open slot and remove card: 手順 4、 2の画像 2
    • The SD card slot can be opened and closed, as depicted by the tool.
    • The SD card itself slides into and out of the metal cover.
    • The gold tipped tines are what read the SD card along its bottom.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
graysonmensah
メンバー登録日: 02/13/15
22 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-4, Michaels Spring 2015 Ohio State, Team 1-4, Michaels Spring 2015人のメンバー
OSU-MICHAELS-S15S1G4
3 メンバー
4のガイドは作成済み
3 件のコメント
That's the micro SD slot. That's not for a SIM card.
Carl Jr - 返信
What if there's no metal cover?
Michael ansley - 返信
That's for the sd card not the sim card
gasparesparza9 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 3,043
