はじめに
This guide describes the step by step process involved in removing the flash chip of the Kyocera Event phone.
必要な工具と部品
Locate the small notch on the bottom right side of the phone.
To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
Remove seven of the 4.9mm tri-head screws. Keep them in a secure location.
Pry the back assembly away from the body on all four sides of the phone.
Start prying at the top and work around.
Remove the buttons for the volume and power-this will allow for easier disassembly.
Detach the Flash Chip from its housing using tweezers.
Once loosened, slide the Flash Chip upward and out of its housing.
Grab the housing on the bottom left side with fingers and pull outwards and towards the bottom of the phone.
Grab the speaker by its black and red wires with tweezers. Pull the wires down and to the right side of the phone.
The speaker wires tend to move back to their original position - you may find it helpful to secure the wires behind the battery terminals to keep your work area clear.
The Flash Chip attaches to the phone using a small, flat brown cord (a "ribbon"). Using tweezers, grab the ribbon as close to its attachment point as possible and pull forcefully to the left.
