はじめに
A battery is essential to turn on the phone. In this guide you will learn how to remove the battery in a Kyocera Event and put another battery to Kyocera Event efficiently.
パーツ
パーツは必要ありません。
  1. Locate the small notch on the bottom right side of the phone. To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off. The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
まとめ
2 の人々がこのガイドを完成させました。
Jen Michaels
メンバー登録日: 2013年08月07日
22 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-1, Michaels Fall 2013 Ohio State, Team 1-1, Michaels Fall 2013人のメンバー
OSU-MICHAELS-F13S1G1
1 メンバー
2のガイドは作成済み
統計データを表示:
過去 24時間: 4
過去 7 日: 26
過去 30 日: 162
今までの合計 2,077
