はじめに
Follow this guide to replace the drivetrain on a 2014 Kushlan cement mixer model 600DDS.
This repair requires two people to complete.
The gearbox will need to be refilled with 8oz of 75W90 gear oil (see operator’s manual).
Properly dispose of used gear oil at a certified collection center.
必要な工具と部品
Use a 13 mm socket to remove the two bolts securing the motor cover to the frame.
Use a 13 mm socket to remove the four bolts securing the motor cage to the frame.
Use a 19 mm socket to remove the 70 mm-long bolt securing the drum to the output shaft.
Use a 10 mm socket to remove the four nuts securing the gearbox to the frame.
Use a Phillips screwdriver to remove the four screws securing the fan cover to the motor.
Use a 8 mm socket to remove the four 135 mm-long bolts securing the motor to the gearbox.
Use a 10 mm socket to remove the following nuts and bolts from the gearbox case:
Five nuts
One 40 mm-long bolt
Use a universal pulley to remove the bearing from the output shaft.
Use a torch to heat the outside of the casing near the bearings.
Tap the outside of the gearbox case with a hammer to knock the bearings out.
If the bearings don't fall out, reheat the casing and try again. If they remain stuck, flip over the gearbox case and use a flathead screwdriver to pry the bearings out.
Apply grease to the new gears and bearings as you install them.
Keep the [[Topic:Kushlan Cement Mixer 600DDS 2014#diagram/19504/hotspot/1657489|gearbox and motor assembly diagram]] accessible during reassembly.
2 の人々がこのガイドを完成させました。
