メインコンテンツにスキップ
Kurio Xtreme Power/Volume Buttons Replacement
必要な工具と部品
  1. Kurio Xtreme Power/Volume Buttons Replacement, Back Panel: 手順 1、 1の画像 1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Power/Volume Buttons Replacement: 手順 2、 2の画像 1 Kurio Xtreme Power/Volume Buttons Replacement: 手順 2、 2の画像 2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Power/Volume Buttons Replacement: 手順 3、 3の画像 1 Kurio Xtreme Power/Volume Buttons Replacement: 手順 3、 3の画像 2 Kurio Xtreme Power/Volume Buttons Replacement: 手順 3、 3の画像 3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Power/Volume Buttons Replacement, Power/Volume Buttons: 手順 4、 1の画像 1
    • Remove the three 4 mm screws on the motherboard with a Phillips #000 screwdriver.
  5. Kurio Xtreme Power/Volume Buttons Replacement: 手順 5、 2の画像 1 Kurio Xtreme Power/Volume Buttons Replacement: 手順 5、 2の画像 2
    • Remove the orange data display ribbon wire above the battery by prying open the ZIF connector with the plastic opening tool.
  6. Kurio Xtreme Power/Volume Buttons Replacement: 手順 6、 2の画像 1 Kurio Xtreme Power/Volume Buttons Replacement: 手順 6、 2の画像 2
    • Remove the orange data display ribbon wire to the left of the battery by prying open the ZIF connector with the plastic opening tool.
  7. Kurio Xtreme Power/Volume Buttons Replacement: 手順 7、 1の画像 1
    • Remove the speakers out of the plastic molds by lifting up the black and red wires.
    • Be careful not to disconnect the black and red wires from the motherboard.
  8. Kurio Xtreme Power/Volume Buttons Replacement: 手順 8、 2の画像 1 Kurio Xtreme Power/Volume Buttons Replacement: 手順 8、 2の画像 2
    • Remove the motherboard by lifting it out of the casing. Set it upside down below the casing.
    • The motherboard will still be connected to the battery and the speakers.
  9. Kurio Xtreme Power/Volume Buttons Replacement: 手順 9、 3の画像 1 Kurio Xtreme Power/Volume Buttons Replacement: 手順 9、 3の画像 2 Kurio Xtreme Power/Volume Buttons Replacement: 手順 9、 3の画像 3
    • Remove the volume buttons and/or power button by soldering them at their bases.
    • Volume down
    • Volume up
    • Power
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Mallory Myers
メンバー登録日: 09/22/15
1,190 ポイント
7のガイドは作成済み
チーム
Baylor, Team 6-10, Williams Fall 2015 Baylor, Team 6-10, Williams Fall 2015人のメンバー
BU-WILLIAMS-F15S6G10
3 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 886
