メインコンテンツにスキップ
Kurio Touch 4S Power Button Replacement
必要な工具と部品
  1. Kurio Touch 4S Power Button Replacement, Power Button: 手順 1、 1の画像 1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Power Button Replacement: 手順 2、 3の画像 1 Kurio Touch 4S Power Button Replacement: 手順 2、 3の画像 2 Kurio Touch 4S Power Button Replacement: 手順 2、 3の画像 3
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top; try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Power Button Replacement: 手順 3、 2の画像 1 Kurio Touch 4S Power Button Replacement: 手順 3、 2の画像 2
    • To remove the battery, make sure the four 5mm Phillips screws on each side of your device is open using the Phillips #1 Screwdriver
    • After you remove your four 5mm Phillips screws, use your plastic opening tool to help you open the plastic cover of your device.
  4. Kurio Touch 4S Power Button Replacement: 手順 4、 1の画像 1
    • After you remove your four 5mm Philips screws use your plastic opening tool to help you open the plastic cover of your device.
  5. Kurio Touch 4S Power Button Replacement: 手順 5、 1の画像 1
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  6. Kurio Touch 4S Power Button Replacement: 手順 6、 1の画像 1
    • Gently remove the plastic cover that is covering the camera.
  7. Kurio Touch 4S Power Button Replacement: 手順 7、 1の画像 1
    • Use Phillips # 1 screw to open the four 5mm Philips screws on the motherboard.
    • Open the screws gently and do not apply too much force as you could damage the motherboard.
  8. Kurio Touch 4S Power Button Replacement: 手順 8、 1の画像 1
    • Use the plastic opener to remove the battery.
  9. Kurio Touch 4S Power Button Replacement: 手順 9、 1の画像 1
    • Use tweezers to remove the black tape that is attached to the motherboard.
  10. Kurio Touch 4S Power Button Replacement: 手順 10、 2の画像 1 Kurio Touch 4S Power Button Replacement: 手順 10、 2の画像 2
    • Detach all the wire that are connected to the motherboard.
    • Detach the camera module and other components that are attached to the motherboard.
  11. Kurio Touch 4S Power Button Replacement: 手順 11、 1の画像 1
    • Remove the motherboard with the help of plastic opener.
    • Detach the power plug before you remove the motherboard.
  12. Kurio Touch 4S Power Button Replacement: 手順 12、 1の画像 1
    • Use tweezers to hold the power button and gently lift it up.
    • Replace the old power button with the new one.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Moin Khan
メンバー登録日: 01/21/15
234 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 6-5, Brown Winter 2015 USF Tampa, Team 6-5, Brown Winter 2015人のメンバー
USFT-BROWN-W15S6G5
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 467
