はじめに
This guide will show you how to replace your front & back camera of your Kurio Touch 4S
  1. Make sure to open the back cover easily using the plastic opening tool.
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Remove back cover by prying away from the Kurio. The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides. The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
    • Remove back cover by prying away from the Kurio.
    • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  3. To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver. To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver. To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • All these screws are identical so don't worry if you miss them up.
  6. Remove the battery because it blocks the plastic shield that covers the camera.
    • Remove the battery because it blocks the plastic shield that covers the camera.
    • Do not remove the wires that are attached to the battery and the motherboard.
  7. Remove the plastic cover that is covering the camera area using tweezers.
    • Remove the plastic cover that is covering the camera area using tweezers.
  8. Separate the two halves of your Kurio Touch 4S. Gently use a brush to remove any dirt or finger prints around the area.
    • Separate the two halves of your Kurio Touch 4S.
    • Gently use a brush to remove any dirt or finger prints around the area.
    • Use the Tweezers to detach the front and back camera from its place.
  9. Remove the copper wires by using the Tweezers to replace your new camera. Remove the copper wires by using the Tweezers to replace your new camera.
    • Remove the copper wires by using the Tweezers to replace your new camera.
まとめ
ある他の人がこのガイドを完成しました。
Khalid AlTamimi
メンバー登録日: 2015年01月21日
251 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 6-5, Brown Winter 2015 USF Tampa, Team 6-5, Brown Winter 2015人のメンバー
USFT-BROWN-W15S6G5
3 メンバー
10のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 211
