メインコンテンツにスキップ
Kurio Touch 4S Front & Rear Facing Cameras Replacement
必要な工具と部品
  1. Kurio Touch 4S Front & Rear Facing Cameras Replacement, Front & Rear Facing Cameras: 手順 1、 1の画像 1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 手順 2、 3の画像 1 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 手順 2、 3の画像 2 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 手順 2、 3の画像 3
    • Remove back cover by prying away from the Kurio.
    • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  3. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 手順 3、 3の画像 1 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 手順 3、 3の画像 2 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 手順 3、 3の画像 3
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
  4. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 手順 4、 1の画像 1
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • All these screws are identical so don't worry if you miss them up.
  5. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 手順 5、 1の画像 1
    • Remove the battery because it blocks the plastic shield that covers the camera.
    • Do not remove the wires that are attached to the battery and the motherboard.
  6. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 手順 6、 1の画像 1
    • Remove the plastic cover that is covering the camera area using tweezers.
  7. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 手順 7、 2の画像 1 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 手順 7、 2の画像 2
    • Separate the two halves of your Kurio Touch 4S.
    • Gently use a brush to remove any dirt or finger prints around the area.
    • Use the Tweezers to detach the front and back camera from its place.
  8. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 手順 8、 2の画像 1 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 手順 8、 2の画像 2
    • Remove the copper wires by using the Tweezers to replace your new camera.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Khalid AlTamimi
メンバー登録日: 01/21/15
275 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 6-5, Brown Winter 2015 USF Tampa, Team 6-5, Brown Winter 2015人のメンバー
USFT-BROWN-W15S6G5
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 242
