はじめに
Accessing the battery is straight-forward, but the replacement requires soldering, and that can be tricky. Soldering involves melting two pieces of metal together so that they become one piece. Replacing the battery should prevent the Kurio 7 from malfunctioning.
必要な工具と部品
Desolder, or separate using the desoldering braid, the marked areas on the motherboard to remove the old battery.
Refer to our soldering guide on how to solder and desolder.
Solder in the new battery. To reassemble your device, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
