メインコンテンツにスキップ
はじめに
If the back panel of your Kurio 7 is broken, this is an easy process to replace it. This also serves as a guide to opening the device for other repairs and replacements.
  1. Begin by removing the rubber cover from the Kurio 7. Begin by removing the rubber cover from the Kurio 7. Begin by removing the rubber cover from the Kurio 7.
    • Begin by removing the rubber cover from the Kurio 7.
  2. Remove the  four 30 mm Phillips #00 screws from the outer case. Remove the  four 30 mm Phillips #00 screws from the outer case.
    • Remove the four 30 mm Phillips #00 screws from the outer case.
  3. Insert the plastic opening tool in the gap between the front cover and the back cover of the device. Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
    • Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
    • Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
    • Be careful not to break off the tabs that hold the front cover and the back cover together.
  4. Once all of the tabs are removed, the back cover should come off easily. Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
    • Once all of the tabs are removed, the back cover should come off easily.
    • Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
終わりに
Replace with a new back panel. To reassemble your device, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
Eric Rice
メンバー登録日: 2014年04月14日
895 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 12-36, Maness Spring 2014 Cal Poly, Team 12-36, Maness Spring 2014人のメンバー
CPSU-MANESS-S14S12G36
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 2,304
