メインコンテンツにスキップ
Kurio 10S Motherboard Replacement
必要な工具と部品
  1. Kurio 10S Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
    • Turn the device over and place it with the screen down on a flat surface that is clean so the screen does not get scratched.
  2. Kurio 10S Motherboard Replacement: 手順 2、 1の画像 1
    • Locate the four screws, two on each side.
    • Using the philips head screwdriver, carefully remove each screw and keep them together in a safe location.
  3. Kurio 10S Motherboard Replacement: 手順 3、 1の画像 1
    • Once all screws are removed, use a spudger to get under a corner and unclip the hooks.
    • Once the spudger is under the cover, slide it all the way around the device, pushing lightly into the device making sure it stays under the cover until all the clips are removed.
  4. Kurio 10S Motherboard Replacement: 手順 4、 1の画像 1
    • The back cover should then be able to easily be removed from the device and you should see the battery and other internal components.
  5. Kurio 10S Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the electrical tape surrounding the battery.
  6. Kurio 10S Motherboard Replacement: 手順 6、 2の画像 1 Kurio 10S Motherboard Replacement: 手順 6、 2の画像 2
    • Locate the red and black wire connections where the battery is connected to the motherboard.
    • Now remove the red and black wires by soldering the ends of the wires off where they connect to the motherboard.
  7. Kurio 10S Motherboard Replacement: 手順 7、 1の画像 1
    • Locate and remove the copper tape connecting the motherboard to the back of the screen
  8. Kurio 10S Motherboard Replacement: 手順 8、 3の画像 1 Kurio 10S Motherboard Replacement: 手順 8、 3の画像 2 Kurio 10S Motherboard Replacement: 手順 8、 3の画像 3
    • Locate the ribbon cables connecting the motherboard to the screen and other peripherals.
    • Carefully lift the black part of the cable connector on the motherboard and pull the cable from the connector.
  9. Kurio 10S Motherboard Replacement: 手順 9、 1の画像 1
    • Locate and remove the four screws holding the motherboard on the device using the philips head screwdriver.
  10. Kurio 10S Motherboard Replacement: 手順 10、 1の画像 1
    • Locate and desolder the wires going to the speakers on each side of the device.
    • The motherboard can now be removed and replaced.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Ryan Kelley
メンバー登録日: 04/07/15
155 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 1-6, Shastany Spring 2015 UMass Dartmouth, Team 1-6, Shastany Spring 2015人のメンバー
UMASSD-SHASTANY-S15S1G6
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 11
今までの合計 986
