はじめに
The trigger assembly that connects the button to the motor can sometimes break. This guide will explain how to replace the trigger assembly.
パーツ
パーツは必要ありません。
  1. In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate. Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  5. The trigger button is held in with light tension clips. Gently pry them back to release.
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  6. Remove the white trigger. Remove the white trigger.
    • Remove the white trigger.
  7. Desolder the contact points between the trigger button and the red wire and also where the plug attaches to the trigger button
    • Desolder the contact points between the trigger button and the red wire and also where the plug attaches to the trigger button
    • Be sure to reference the how to solder video posted to the device page
まとめ
2 の人々がこのガイドを完成させました。
Ian Hancock
メンバー登録日: 2014年10月22日
372 ポイント
3のガイドは作成済み
チーム
Baylor, Team 4-2, Williams Fall 2014 Baylor, Team 4-2, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S4G2
3 メンバー
4のガイドは作成済み
統計データを表示:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 58
今までの合計 2,408
