メインコンテンツにスキップ
Krups 963 Water Heater Replacement
必要な工具と部品
  1. Krups 963 Water Heater Replacement, Removing Bottom Screws: 手順 1、 1の画像 1
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Krups 963 Water Heater Replacement: 手順 2、 1の画像 1
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. Krups 963 Water Heater Replacement: 手順 3、 1の画像 1
    • Remove the bottom cover from the machine and slide it down the power cord.
  4. Krups 963 Water Heater Replacement, Disassembling Krups 963 Top Cover: 手順 4、 1の画像 1
    • Remove the three 60mm Phillips size 0 screws holding the top cover on.
  5. Krups 963 Water Heater Replacement: 手順 5、 1の画像 1
    • Remove the top cap of the machine by turning it in a counter-clockwise motion (left hand in the picture), Check inside the water chamber, and if the silicone washer is inside, having fallen from the underside of the lid, retrieve it and reattach to the lid.
    • Remove the entire pressure valve stem that is attached to the side of the espresso machine: using a crescent wrench, turn the six-sided stem tube counter-clockwise; you'll find it best to apply the wrench as close to the wall of the espresso machine (farthest away from the right hand shown in the photo).
  6. Krups 963 Water Heater Replacement: 手順 6、 1の画像 1
    • Remove the grey plastic ring from the rim of the filter basket holder.
  7. Krups 963 Water Heater Replacement: 手順 7、 1の画像 1
    • Lift and remove the top black plastic cover from the machine.
  8. Krups 963 Water Heater Replacement, Water Heater: 手順 8、 2の画像 1 Krups 963 Water Heater Replacement, Water Heater: 手順 8、 2の画像 2
    • Use a Phillip size 2 screw driver to remove the four 15mm screws holding the pump to the machine's base.
    • Lift the water heater up and remove it from the base.
終わりに
作成者
3人の作成者と共同で作成されました。
Wyatt Hall
メンバー登録日: 10/13/14
842 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 6-25, Maness Fall 2014 Cal Poly, Team 6-25, Maness Fall 2014人のメンバー
CPSU-MANESS-F14S6G25
4 メンバー
7のガイドは作成済み
2 件のコメント
Where do you get the new heater to replace the broken one that does not work?
Stephanie Scoby - 返信
The broken heating element is removed. Where do you get a new one to replace the broken one?
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 26
今までの合計 3,318
