メインコンテンツにスキップ
Korg Toneworks AX1500G Pedal Switch Replacement
必要な工具と部品
  1. Korg Toneworks AX1500G Pedal Switch Replacement, Pedal Switch: 手順 1、 1の画像 1
    • Remove the black 8.0mm Phillips screws from the back of the Pedal Board.
    • Be careful when working with small electronics, as many of the components are fragile.
  2. Korg Toneworks AX1500G Pedal Switch Replacement: 手順 2、 3の画像 1 Korg Toneworks AX1500G Pedal Switch Replacement: 手順 2、 3の画像 2 Korg Toneworks AX1500G Pedal Switch Replacement: 手順 2、 3の画像 3
    • Remove the back panel of the board.
  3. Korg Toneworks AX1500G Pedal Switch Replacement: 手順 3、 1の画像 1
    • Unscrew the five golden 8.0mm Phillips screws holding down the left circuit board.
    • Be careful not to hit to metal parts on the circuit board, this could cause sparks and failure.
  4. Korg Toneworks AX1500G Pedal Switch Replacement: 手順 4、 3の画像 1 Korg Toneworks AX1500G Pedal Switch Replacement: 手順 4、 3の画像 2 Korg Toneworks AX1500G Pedal Switch Replacement: 手順 4、 3の画像 3
    • Carefully unplug three wires connecting the left circuit board to the right circuit board.
    • The wires may be stuck and difficult to remove. Try to pull from the plastic part.
  5. Korg Toneworks AX1500G Pedal Switch Replacement: 手順 5、 3の画像 1 Korg Toneworks AX1500G Pedal Switch Replacement: 手順 5、 3の画像 2 Korg Toneworks AX1500G Pedal Switch Replacement: 手順 5、 3の画像 3
    • The circuit board is still connected at this point.
    • Carefully pull out the circuit board and turn it over.
    • Unplug the last cable connecting it to the other large circuit board.
  6. Korg Toneworks AX1500G Pedal Switch Replacement: 手順 6、 1の画像 1
    • Unscrew the two 8.0 mm black Phillips screws from the small circuit board.
  7. Korg Toneworks AX1500G Pedal Switch Replacement: 手順 7、 3の画像 1 Korg Toneworks AX1500G Pedal Switch Replacement: 手順 7、 3の画像 2 Korg Toneworks AX1500G Pedal Switch Replacement: 手順 7、 3の画像 3
    • Gently pull out the small circuit board by the purple wire.
  8. Korg Toneworks AX1500G Pedal Switch Replacement: 手順 8、 3の画像 1 Korg Toneworks AX1500G Pedal Switch Replacement: 手順 8、 3の画像 2 Korg Toneworks AX1500G Pedal Switch Replacement: 手順 8、 3の画像 3
    • Mark the wire connected to the small circuit board so for future reference.
  9. Korg Toneworks AX1500G Pedal Switch Replacement: 手順 9、 3の画像 1 Korg Toneworks AX1500G Pedal Switch Replacement: 手順 9、 3の画像 2 Korg Toneworks AX1500G Pedal Switch Replacement: 手順 9、 3の画像 3
    • Soldering Irons can be very dangerous if you are inexperienced.
    • Desolder the wires connecting to the board and remove the board.
    • Solder the new foot switch circuit on
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Gabriel Maraboto
メンバー登録日: 09/29/15
200 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 14-6, Green Fall 2015 Cal Poly, Team 14-6, Green Fall 2015人のメンバー
CPSU-GREEN-F15S14G6
5 メンバー
6のガイドは作成済み
3 件のコメント
Thanks! My Ax1500g's pedal switch volume is failing, and not reaching the 100% volume, not even 50%. I've opened the pedalboard and removed the pedal switch, but I notice It doesn't have any true connection to the switchboard but an LED with a PhotoSensor that may be blocked by a plastic in the pedal itself, is that how it works? I was expecting a Potenciometer.
Where can I buy the pedal switch board replacement?
309001200 PHOTO TR RPM-22PB N OR P KLM-2251 AX150 1
312051900 PHOTO SENSOR SIM-22ST Q OR R KLM-2251 AX150 1
Thanks
Martin Jofre - 返信
Bro
Thers is some noise comeing when i connect the cable
I give to one shop
3 times. I took the shop he is cheater i lost my money
I need to fix it bro
I need ur help
Samuel Arun - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 31
今までの合計 4,846
