メインコンテンツにスキップ
Koosh Vortex Tornado Loading Spring Replacement
必要な工具と部品
  1. Koosh Vortex Tornado Loading Spring Replacement, Barrel Shield Spring: 手順 1、 1の画像 1
    • Remove the fourteen 15 mm Phillips #1 screws on the side of the body.
  2. Koosh Vortex Tornado Loading Spring Replacement: 手順 2、 1の画像 1
    • Pull the halves of the toy gun apart to show the inside. Set the left half aside (all of the inside components are on the right half).
  3. Koosh Vortex Tornado Loading Spring Replacement: 手順 3、 1の画像 1
    • Using a spudger, unhook the barrel shield's spring from the right half of the toy gun. One side should still be connected to the shield barrel shield.
  4. Koosh Vortex Tornado Loading Spring Replacement, Trigger: 手順 4、 1の画像 1
    • Slide the barrel shield and shield slide off of the gun and set aside.
  5. Koosh Vortex Tornado Loading Spring Replacement: 手順 5、 1の画像 1
    • Slide the rubber ring off of the barrel and set it aside.
  6. Koosh Vortex Tornado Loading Spring Replacement: 手順 6、 1の画像 1
    • Lift the yellow trigger from its pin and set aside.
  7. Koosh Vortex Tornado Loading Spring Replacement, Loading Spring: 手順 7、 1の画像 1
    • Use a Phillips #1 screwdriver to unscrew the two 12 mm long washer head screws from the yellow loading bar lever.
  8. Koosh Vortex Tornado Loading Spring Replacement: 手順 8、 1の画像 1
    • Lift the yellow lever bar out of place and set aside.
  9. Koosh Vortex Tornado Loading Spring Replacement: 手順 9、 1の画像 1
    • Use a Phillips #1 Screwdriver to unscrew the six 10 mm long screws from the central firing assembly.
    • Use Phillips #1 Screwdriver to unscrew the four 9 mm long screws from the central firing assembly.
  10. Koosh Vortex Tornado Loading Spring Replacement: 手順 10、 1の画像 1
    • Pull the shell of the central firing assembly aside off (contains the loading spring).
  11. Koosh Vortex Tornado Loading Spring Replacement: 手順 11、 2の画像 1 Koosh Vortex Tornado Loading Spring Replacement: 手順 11、 2の画像 2
    • Open the back side of the central firing assembly apart to expose the loading spring. Remove it, and change it with your desired spring.
    • The two sides cannot be fully separated due to a pin holding the yellow collar tightly together.
終わりに
作成者
4人の作成者と共同で作成されました。
Lingbin Meng
メンバー登録日: 02/16/16
204 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 2-4, Harley Spring 2016 IUPUI, Team 2-4, Harley Spring 2016人のメンバー
IUPUI-HARLEY-S16S2G4
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 21
今までの合計 359
