はじめに
If the wind and rewind dials on the top of the camera are hard to turn or visibly damaged, they may need to be adjusted or replaced. This guide will walk you through the steps of removing the dials. Please make sure you have all the necessary tools before you start.
必要な工具と部品
この手順で使用する道具:Flathead 3/32" or 2.5 mm Screwdriver$5.49
While holding the wind dial with one hand, remove the 2.8mm flathead screw that holds it in place with the 2.5mm flathead screwdriver.
もう少しです!
終わりに
