Turn the camera so the bottom is facing up with the front-facing away.
Unscrew the 6.2mm Phillips screw on the top right.
The front cover is now unscrewed and should be lifted evenly and removed.
To remove other screws, metal panel must be lifted up slightly to access.
Lift metal panel and insert screwdriver through holes in panel to reach screws underneath. Remove the two 6.2mm Phillips screws.
Look at the black plate on the right side of the lens that the metal plate is resting on.
Unscrew two 6.2mm Phillips screws on the black plate next to the lens.
At this point, all screws are removed and lens can should be carefully lifted and removed, including both plates and the plastic ring around the lens.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
