メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kodak S100 EF Lens Replacement
必要な工具と部品
  1. Kodak S100 EF Lens Replacement, Front Cover: 手順 1、 1の画像 1
    • Have the camera facing upwards and the flash closest to you.
    • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
  2. Kodak S100 EF Lens Replacement: 手順 2、 1の画像 1
    • Flip the camera over to the other side-with flash farthest from you.
    • Unscrew top two 6.2mm Phillips screws on this side.
  3. Kodak S100 EF Lens Replacement: 手順 3、 1の画像 1
    • Turn the camera so the bottom is facing up with the front-facing away.
    • Unscrew the 6.2mm Phillips screw on the top right.
    • The front cover is now unscrewed and should be lifted evenly and removed.
  4. Kodak S100 EF Lens Replacement, Lens: 手順 4、 1の画像 1
    • Remove the two 6.2mm Phillips screws on either side of the lens securing the metal plate.
  5. Kodak S100 EF Lens Replacement: 手順 5、 1の画像 1
    • Pull aside the plastic piece resting atop the metal lens plate in order to access the other screws.
  6. Kodak S100 EF Lens Replacement: 手順 6、 1の画像 1
    • To remove other screws, metal panel must be lifted up slightly to access.
    • Lift metal panel and insert screwdriver through holes in panel to reach screws underneath. Remove the two 6.2mm Phillips screws.
  7. Kodak S100 EF Lens Replacement: 手順 7、 1の画像 1
    • Look at the black plate on the right side of the lens that the metal plate is resting on.
    • Unscrew two 6.2mm Phillips screws on the black plate next to the lens.
    • At this point, all screws are removed and lens can should be carefully lifted and removed, including both plates and the plastic ring around the lens.
終わりに
作成者
7人の作成者と共同で作成されました。
Michelle
メンバー登録日: 04/04/11
131 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 25-28, Garner Spring 2011 Cal Poly, Team 25-28, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S25G28
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 2,170
