メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kodak S100 EF Film Replacement
必要な工具と部品
  1. Kodak S100 EF Film Replacement, Film: 手順 1、 1の画像 1
    • Lift up the lever from the center of the film roller.
    • Turn it clockwise to roll up the film until you feel the roller release, indicating all the film has been rolled up.
  2. Kodak S100 EF Film Replacement: 手順 2、 1の画像 1
    • On the far left side on the back of the camera there is a switch that says "open."
    • Slide the button up to the top where it says "open."
    • This should pop open the door, revealing the rolled up film inside.
  3. Kodak S100 EF Film Replacement: 手順 3、 1の画像 1
    • To take out the old film and insert the new, you must lift up on the film roller.
    • Pull up on the lever to pop the roller up which will release the film.
    • Remove the old roll of film and slide in the new roll.
    • Push the roller back down to secure the film.
  4. Kodak S100 EF Film Replacement: 手順 4、 1の画像 1
    • To prepare the film for use, slightly pull the tail of the film out of the roll.
    • Drag the tail end of the film past the rotating column on the right side.
    • Attach the hooks at the base of the column to the holes located at the bottom of the film.
  5. Kodak S100 EF Film Replacement: 手順 5、 1の画像 1
    • After the film is secured, close the camera door.
    • Make sure the lever is put back in place on the film roller.
    • Use the scroll wheel to advance the film until it is ready to take pictures.
終わりに
Once the film is in place-to reassemble the camera-close the camera door and make sure the scroll wheel is pushed back down.
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Michelle
メンバー登録日: 04/04/11
131 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 25-28, Garner Spring 2011 Cal Poly, Team 25-28, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S25G28
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 19
過去 30 日: 69
今までの合計 9,884
