メインコンテンツにスキップ
Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution
必要な工具と部品
  1. Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Identify the problem: 手順 1、 1の画像 1
    • Identify that your printer is jammed. This is usually indicated by the paper light blinking quickly.
  2. Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Removing the paper tray: 手順 2、 1の画像 1
    • Gently pull the paper tray out of the printing dock to remove it.
    • When the paper tray is empty, the paper light should glow a steady amber.
  3. Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Disconnecting the power adapter: 手順 3、 2の画像 1 Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Disconnecting the power adapter: 手順 3、 2の画像 2
    • Disconnect the power adapter from the printer for 10 seconds, and then reconnect the cord.
    • On some models, you may have to press the power button in addition to plugging in the power adapter.
    • Wait for the printer to initialize in order for the jammed paper to exit from the back side.
    • Notice: Carefully remove the paper if it does not automatically eject.
  4. Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Removing the paper supply: 手順 4、 1の画像 1
    • With the paper tray in hand, open the front lid in order to gain access to the paper supply.
    • Take hold of the paper bundle, and carefully “fan” it to keep the sheets from sticking together.
  5. Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Reload and reinstall the paper tray: 手順 5、 1の画像 1
    • Reload the paper tray by sliding the paper bundle back into the intended slot, and then close the lid.
    • Next, slide the paper tray in the printer tray slot until the tray locks into place.
    • To ensure the paper tray fits squarely on the printer dock, make sure to keep the paper tray cover all the way open while installing.
    • Press the power or print button to clear the paper error and resume printing.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Henry Ta
メンバー登録日: 10/13/16
119 ポイント
1ガイドが承認済み
チーム
University of Maine, Team 1-6, Diaz Fall 2016 University of Maine, Team 1-6, Diaz Fall 2016人のメンバー
UMAINE-DIAZ-F16S1G6
2 メンバー
1のガイドは作成済み
1件のガイドコメント
My doc is only print half of pic what can ido
Amy Winfree - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 51
今までの合計 4,281
