この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide demonstrates how to replace the camera's logic board.
必要な工具と部品
Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
この手順で使用する道具:Anti-Static Wrist Strap$7.95
Before removing back cover, it is advisable to use an anti-static wrist strap to prevent damage to electronics.
この手順で使用する道具:Phillips #00 Screwdriver$5.49
Remove all 7 screws:
Hold the camera firmly with one hand so that you can still see a screw.
Place the Philips 00(Found here)screwdriver into the screw.
Turn the screwdriver to the left until it is free.
Repeat for the remaining screws.
Open the battery door.
Press thumb firmly on battery door and slide it in the direction of the arrow.
Lift thumb allowing the door to swing open.
Remove the medal housing from the logic board by carefully peeling the yellow tape off of the metal housing.
