メインコンテンツにスキップ
Kodak EasyShare Z740 LCD Screen Replacement
必要な工具と部品
  1. Kodak EasyShare Z740 LCD Screen Replacement, Battery: 手順 1、 3の画像 1 Kodak EasyShare Z740 LCD Screen Replacement, Battery: 手順 1、 3の画像 2 Kodak EasyShare Z740 LCD Screen Replacement, Battery: 手順 1、 3の画像 3
    • Slide the door on the bottom of the camera in the direction of the open symbol with your finger.
    • Release and the door will pop open.
  2. Kodak EasyShare Z740 LCD Screen Replacement: 手順 2、 2の画像 1 Kodak EasyShare Z740 LCD Screen Replacement: 手順 2、 2の画像 2
    • Slide the battery out.
  3. Kodak EasyShare Z740 LCD Screen Replacement, Lens Cover: 手順 3、 2の画像 1 Kodak EasyShare Z740 LCD Screen Replacement, Lens Cover: 手順 3、 2の画像 2
    • Remove lens cover from the camera by squeezing the protruding button on each side of the cover and pulling.
  4. Kodak EasyShare Z740 LCD Screen Replacement: 手順 4、 3の画像 1 Kodak EasyShare Z740 LCD Screen Replacement: 手順 4、 3の画像 2 Kodak EasyShare Z740 LCD Screen Replacement: 手順 4、 3の画像 3
    • Pull the lens cover string toward the ground so that the loop underneath the metal slab is on top of the cover string.
    • Push up so that the string starts to come out of the top of the loop.
    • Grab the string from above the loop and pull.
  5. Kodak EasyShare Z740 LCD Screen Replacement: 手順 5、 2の画像 1 Kodak EasyShare Z740 LCD Screen Replacement: 手順 5、 2の画像 2
    • Feed the string on top into the metal slab while pulling the loop toward you until the plastic piece stops you from pulling any further.
  6. Kodak EasyShare Z740 LCD Screen Replacement: 手順 6、 3の画像 1 Kodak EasyShare Z740 LCD Screen Replacement: 手順 6、 3の画像 2 Kodak EasyShare Z740 LCD Screen Replacement: 手順 6、 3の画像 3
    • Separate the two pieces of the loop and pull the lens cover up in between them.
  7. Kodak EasyShare Z740 LCD Screen Replacement: 手順 7、 3の画像 1 Kodak EasyShare Z740 LCD Screen Replacement: 手順 7、 3の画像 2 Kodak EasyShare Z740 LCD Screen Replacement: 手順 7、 3の画像 3
    • Pull the lens cover and the sting will come out of the metal slab.
  8. Kodak EasyShare Z740 LCD Screen Replacement, Back Cover: 手順 8、 3の画像 1 Kodak EasyShare Z740 LCD Screen Replacement, Back Cover: 手順 8、 3の画像 2 Kodak EasyShare Z740 LCD Screen Replacement, Back Cover: 手順 8、 3の画像 3
    • Place lens cover back on the lens to prevent scratches or debris but leave string detached.
    • Remove a total of six 3.968mm Phillips #00 screws. Two each from the left side, bottom, and right side.
  9. Kodak EasyShare Z740 LCD Screen Replacement: 手順 9、 3の画像 1 Kodak EasyShare Z740 LCD Screen Replacement: 手順 9、 3の画像 2 Kodak EasyShare Z740 LCD Screen Replacement: 手順 9、 3の画像 3
    • Pull the back cover away from the front cover.
    • You may need to use a plastic opening tool as a wedge if it does not come apart by easily.
  10. Kodak EasyShare Z740 LCD Screen Replacement: 手順 10、 1の画像 1
    • Separate the back cover from the front cover.
  11. Kodak EasyShare Z740 LCD Screen Replacement, LCD Screen: 手順 11、 3の画像 1 Kodak EasyShare Z740 LCD Screen Replacement, LCD Screen: 手順 11、 3の画像 2 Kodak EasyShare Z740 LCD Screen Replacement, LCD Screen: 手順 11、 3の画像 3
    • Flip the LCD screen down.
  12. Kodak EasyShare Z740 LCD Screen Replacement: 手順 12、 3の画像 1 Kodak EasyShare Z740 LCD Screen Replacement: 手順 12、 3の画像 2 Kodak EasyShare Z740 LCD Screen Replacement: 手順 12、 3の画像 3
    • Locate the two sets of black tabs connecting the flat orange cables to the motherboard.
    • Slide the 2 sets of tabs down with a tool or your finger to release the cables.
  13. Kodak EasyShare Z740 LCD Screen Replacement: 手順 13、 2の画像 1 Kodak EasyShare Z740 LCD Screen Replacement: 手順 13、 2の画像 2
    • Gently pull the LCD screen down until the orange cables separate from the motherboard.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Kirsten Price
メンバー登録日: 09/17/14
406 ポイント
6のガイドは作成済み
チーム
University of Kentucky Louisville, Team 1-4, Mathis Fall 2014 University of Kentucky Louisville, Team 1-4, Mathis Fall 2014人のメンバー
LOUISVILLE-MATHIS-F14S1G4
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 20
今までの合計 889
