はじめに
This guide demonstrates how to install a memory card.
必要な工具と部品
In order to remove the SD memory card, you will first need to open up the cover. To open the cover, slide the latch holding the cover in place to the left.
Remove your hand from the latch and the cover should pop open. The SD memory card is located near the top above the battery. As shown in the final picture of this step.
ある他の人がこのガイドを完成しました。
