はじめに
This tutorial demonstrates how to remove the back cover from the camera.
  1. Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open. Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
    • Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
  2. Next, press down on the red lever which holds the battery in place.
    • Next, press down on the red lever which holds the battery in place.
  3. Once the battery has popped out of the compartment, simply pull it out of the camera. Once the battery has popped out of the compartment, simply pull it out of the camera.
    • Once the battery has popped out of the compartment, simply pull it out of the camera.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Make sure that the lens cover is on the Kodak EasyShare whenever working with one of these guides. Also, make sure to keep track of the screws you remove throughout these step by step guides. Losing a screw could inhibit the ability to reassemble the camera. Begin by removing the first screw located on the back of the camera.
    • Make sure that the lens cover is on the Kodak EasyShare whenever working with one of these guides.
    • Also, make sure to keep track of the screws you remove throughout these step by step guides. Losing a screw could inhibit the ability to reassemble the camera.
    • Begin by removing the first screw located on the back of the camera.
  6. Next, remove the two screws located on the right side of the camera. Next, remove the two screws located on the right side of the camera.
    • Next, remove the two screws located on the right side of the camera.
  7. After removing the screws located on the right side, remove the six screws located on the bottom of the camera. After removing the screws located on the right side, remove the six screws located on the bottom of the camera.
    • After removing the screws located on the right side, remove the six screws located on the bottom of the camera.
  8. Lastly, remove the two screws located on the left side of the camera. Lastly, remove the two screws located on the left side of the camera.
    • Lastly, remove the two screws located on the left side of the camera.
  9. Once all eleven screws have been removed, use Plastic Opening Tools to take off the back cover. Insert the plastic opening tool and apply leverage on each side of the camera. The recommended spots to apply leverage are shown in these pictures. Insert the plastic opening tool and apply leverage on each side of the camera. The recommended spots to apply leverage are shown in these pictures.
    • Once all eleven screws have been removed, use Plastic Opening Tools to take off the back cover.
      • Insert the plastic opening tool and apply leverage on each side of the camera. The recommended spots to apply leverage are shown in these pictures.
  10. Apply pressure on the left and right side of the camera and pull the back cover away from the device. Once the back cover has been successfully removed, you should have a total of eleven screws as well as the bottom cover separated from the camera. Once the back cover has been successfully removed, you should have a total of eleven screws as well as the bottom cover separated from the camera.
    • Apply pressure on the left and right side of the camera and pull the back cover away from the device.
    • Once the back cover has been successfully removed, you should have a total of eleven screws as well as the bottom cover separated from the camera.
まとめ
2 の人々がこのガイドを完成させました。
katie newman
メンバー登録日: 2010年10月28日
30 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 5-16, Maness Fall 2010 Cal Poly, Team 5-16, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S5G16
4 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,177
