はじめに
This camera has easy access to the battery. The place in which you would find the battery also houses the memory card. Don't be alarmed, because there is a diagram on the inside that just incase you didn't know which went into which slot it can show you.
ツール
ツールは指定されていません。
パーツ
Flip the camera upside down so the battery compartment is towards you. Follow the arrows with your thumb to slide open the hatch to expose the battery and memory card.
Close it back up and you're ready to go!
ある他の人がこのガイドを完成しました。
