メインコンテンツにスキップ
Kodak EasyShare M381 Screen Replacement
必要な工具と部品
  1. Kodak EasyShare M381 Screen Replacement, Battery: 手順 1、 2の画像 1 Kodak EasyShare M381 Screen Replacement, Battery: 手順 1、 2の画像 2
    • First, press in and slide forward the battery latch as indicated by the arrow.
  2. Kodak EasyShare M381 Screen Replacement: 手順 2、 1の画像 1
    • Press down on battery until you hear a click and release it. Battery should easily slide out.
  3. Kodak EasyShare M381 Screen Replacement, Back Panel Frame: 手順 3、 3の画像 1 Kodak EasyShare M381 Screen Replacement, Back Panel Frame: 手順 3、 3の画像 2 Kodak EasyShare M381 Screen Replacement, Back Panel Frame: 手順 3、 3の画像 3
    • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
    • Using a magnetized surface to keep from losing screws may be very helpful.
  4. Kodak EasyShare M381 Screen Replacement: 手順 4、 2の画像 1 Kodak EasyShare M381 Screen Replacement: 手順 4、 2の画像 2
    • Using both hands, carefully pull the frame apart from the camera.
  5. Kodak EasyShare M381 Screen Replacement, Screen: 手順 5、 1の画像 1
    • Remove the two 3.85 mm screws on the bottom right of the camera, as indicated.
  6. Kodak EasyShare M381 Screen Replacement: 手順 6、 1の画像 1
    • Remove dial button located on top of camera, by gently pulling up.
  7. Kodak EasyShare M381 Screen Replacement: 手順 7、 2の画像 1 Kodak EasyShare M381 Screen Replacement: 手順 7、 2の画像 2
    • Starting at one side, carefully work the chrome frame off of the camera itself.
    • Be careful not to disturb the shutter or flash buttons on top of the camera.
  8. Kodak EasyShare M381 Screen Replacement: 手順 8、 1の画像 1
    • On the right side of the camera, locate and remove the two 3.25 mm screws as highlighted.
  9. Kodak EasyShare M381 Screen Replacement: 手順 9、 3の画像 1 Kodak EasyShare M381 Screen Replacement: 手順 9、 3の画像 2 Kodak EasyShare M381 Screen Replacement: 手順 9、 3の画像 3
    • Carefully lift the motherboard panel up, pulling towards the left. Make sure you do not rip the blue ribbon.
    • Using a plastic opening tool, gently lift up on the ribbon fastener until it is in an upright position.
    • Slide panel away from camera.
  10. Kodak EasyShare M381 Screen Replacement: 手順 10、 2の画像 1 Kodak EasyShare M381 Screen Replacement: 手順 10、 2の画像 2
    • Using a plastic opening tool, gently lift ribbon clamp as indicated to remove the screen ribbon from the motherboard.
    • Screen should now be detached. Gently lift it away from the base of the camera.
終わりに
作成者
4人の作成者と共同で作成されました。
Christina Hamby
メンバー登録日: 01/30/15
449 ポイント
4のガイドは作成済み
チーム
University of Kentucky Louisville, Team 1-4, Rountree Winter 2015 University of Kentucky Louisville, Team 1-4, Rountree Winter 2015人のメンバー
LOUISVILLE-ROUNTREE-W15S1G4
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 24
今までの合計 491
