メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
パーツ
パーツは指定されていません。
  1. Place thumb firmly on battery cover. Slide thumb right, the cover should follow and pop up.
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Place thumb on orange tab and pull back towards screen. The battery should pop up.
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Remove screws from along outer edge of casing. There are 6 screws in total. Righty tighty, lefty loosey!
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Gently lift off front and back casing. Gently lift off front and back casing. Gently lift off front and back casing.
    • Gently lift off front and back casing.
  5. Remove screws along side. Gently peel off side casing. Gently peel off side casing.
    • Remove screws along side.
    • Gently peel off side casing.
  6. Open the battery door and identify the retaining pin. Push retaining pin out with small tweezers. Push retaining pin out with small tweezers.
    • Open the battery door and identify the retaining pin.
    • Push retaining pin out with small tweezers.
  7. Once pin is out halfway, close door to ensure no loose parts get lost. Continue to pull out the remaining length of the pin. Continue to pull out the remaining length of the pin.
    • Once pin is out halfway, close door to ensure no loose parts get lost.
    • Continue to pull out the remaining length of the pin.
  8. Gently lift off door cover. Gently lift off door cover.
    • Gently lift off door cover.
終わりに
Kyanna
メンバー登録日: 2014年03月13日
313 ポイント
3のガイドは作成済み
チーム
New Mexico State, Team 1-2, Easley Spring 2014 New Mexico State, Team 1-2, Easley Spring 2014人のメンバー
NMSU-EASLEY-S14S1G2
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 72
