メインコンテンツにスキップ
Kodak EasyShare LS743 Top and Menu Button Replacement
必要な工具と部品
  1. Kodak EasyShare LS743 Top and Menu Button Replacement, Battery: 手順 1、 1の画像 1
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 2、 1の画像 1
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Top and Menu Button Replacement, Kodak EasyShare LS743 Camera Case Disassembly: 手順 3、 3の画像 1 Kodak EasyShare LS743 Top and Menu Button Replacement, Kodak EasyShare LS743 Camera Case Disassembly: 手順 3、 3の画像 2 Kodak EasyShare LS743 Top and Menu Button Replacement, Kodak EasyShare LS743 Camera Case Disassembly: 手順 3、 3の画像 3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 4、 3の画像 1 Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 4、 3の画像 2 Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 4、 3の画像 3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 5、 2の画像 1 Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 5、 2の画像 2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Top and Menu Button Replacement, Top and menu buttons: 手順 6、 2の画像 1 Kodak EasyShare LS743 Top and Menu Button Replacement, Top and menu buttons: 手順 6、 2の画像 2
    • Remove the top panel screw (1x 4.37mm).
  7. Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 7、 2の画像 1 Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 7、 2の画像 2
    • Remove the top panel.
  8. Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 8、 2の画像 1 Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 8、 2の画像 2
    • Remove the back panel screws (1x 3.33mm, and 1x 3.40mm).
  9. Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 9、 3の画像 1 Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 9、 3の画像 2 Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 9、 3の画像 3
    • Separate the inner casing from the tripod mount.
  10. Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 10、 3の画像 1 Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 10、 3の画像 2 Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 10、 3の画像 3
    • Gently pull the orange tab out of the circuit board.
  11. Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 11、 2の画像 1 Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 11、 2の画像 2
    • Carefully separate and flip over the LCD panel to expose the central circuit board.
  12. Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 12、 1の画像 1
    • Remove the (1x 3.33mm) screw from the menu button panel .
  13. Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 13、 2の画像 1 Kodak EasyShare LS743 Top and Menu Button Replacement: 手順 13、 2の画像 2
    • Pull the second orange tab from the circuit board and remove the buttons.
終わりに
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Michael
メンバー登録日: 06/24/10
63 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 2-8, Johann Summer 2010 Cal Poly, Team 2-8, Johann Summer 2010人のメンバー
CPSU-JOHANN-R10S2G8
5 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 11
今までの合計 1,362
