メインコンテンツにスキップ
Kodak EasyShare CD82 Lens Assembly Replacement
必要な工具と部品
  1. Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: 手順 1、 3の画像 1 Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: 手順 1、 3の画像 2 Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: 手順 1、 3の画像 3
    • Remove the batteries and the memory card from the device.
    • Remove the two screws located at the bottom of the camera.
  2. Kodak EasyShare CD82 Lens Assembly Replacement: 手順 2、 3の画像 1 Kodak EasyShare CD82 Lens Assembly Replacement: 手順 2、 3の画像 2 Kodak EasyShare CD82 Lens Assembly Replacement: 手順 2、 3の画像 3
    • Remove the two screws on the side of the device, to left of the camera lens.
    • Remove the two screws on side of the device, to the right of the camera lens.
    • Pry the casing apart at the seems, starting at the battery compartment.
  3. Kodak EasyShare CD82 Lens Assembly Replacement: 手順 3、 3の画像 1 Kodak EasyShare CD82 Lens Assembly Replacement: 手順 3、 3の画像 2 Kodak EasyShare CD82 Lens Assembly Replacement: 手順 3、 3の画像 3
    • Remove the front casing from the mid-frame, first.
    • Continue to remove the back casing from the mid-frame.
    • Do not remove the LCD screen from the device once it becomes visible.
  4. Kodak EasyShare CD82 Lens Assembly Replacement: 手順 4、 3の画像 1 Kodak EasyShare CD82 Lens Assembly Replacement: 手順 4、 3の画像 2 Kodak EasyShare CD82 Lens Assembly Replacement: 手順 4、 3の画像 3
    • Flip the LCD screen out of the holder from the top to reveal ribbon cable.
    • This camera had some obvious water damage..
    • Remove the three screws from the LCD holder
    • Dislodge the LCD screen holder from the circuit board connector.
  5. Kodak EasyShare CD82 Lens Assembly Replacement: 手順 5、 3の画像 1 Kodak EasyShare CD82 Lens Assembly Replacement: 手順 5、 3の画像 2 Kodak EasyShare CD82 Lens Assembly Replacement: 手順 5、 3の画像 3
    • Disconnect the logic board from the frame on the right side of the device.
    • Remove the small ribbon cable, connecting the button board to the logic board, with small pair of tweezers or hemostat.
    • Remove the screw on the top right side of the device connecting the LCD screen holder to the midframe.
    • Move the black clip into the upward position to disconnect the cable.
    • You will now be able to remove the LCD screen and its holder from the device.
  6. Kodak EasyShare CD82 Lens Assembly Replacement: 手順 6、 3の画像 1 Kodak EasyShare CD82 Lens Assembly Replacement: 手順 6、 3の画像 2 Kodak EasyShare CD82 Lens Assembly Replacement: 手順 6、 3の画像 3
    • Flip the black clips of the connectors into the opposite direction. Remove the lens and CCD cable.
    • Remove the two screws securing the lens to the midframe.
    • These are missing screws for the CCD sensor, lost in a previous dismantling.
    • Remove the single screw securing the lens to the mid-frame. The lens will now be loose.
    • Push the lens out of the frame in an angular direction, and remove.
  7. Kodak EasyShare CD82 Lens Assembly Replacement: 手順 7、 1の画像 1
    • Insert the new lens the same way it was removed.
    • Clean and reassemble the camera.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
oldturkey03
メンバー登録日: 09/29/10
782,419 ポイント
119のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
33 メンバー
544のガイドは作成済み
コメント 1 件
When it says "Dislodge the LCD screen holder from the circuit board connector" does it mean that I can break that solder without desoldering and it's okay?
Sith Siri - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 1,670
