はじめに
Use this guide to remove and install the front case.
必要な工具と部品
Position the camera with the bottom facing up.
Slide the battery cover in the direction of the arrow with your finger gently.
Remove the batteries
Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
2 on the left
2 on the right
3 on the bottom
Keep the battery door open
Firmly grasp the front casing and pull away from the camera.
2 の人々がこのガイドを完成させました。
