メインコンテンツにスキップ
はじめに
Use this guide to remove the back case.
パーツ
パーツは指定されていません。
  1. Position the camera with the bottom facing up. With your finger, slide the battery cover in the direction of open arrow. The battery cover will spring open, so be careful to lift it up gently.
    • Position the camera with the bottom facing up.
    • With your finger, slide the battery cover in the direction of open arrow.
    • The battery cover will spring open, so be careful to lift it up gently.
  2. iPhone X用修理キット
    Warranty up? No worries, we’ve got the fix.
    ショップを見る
    iPhone X用修理キット
    ショップを見る
  3. Use a Phillips #00 screwdriver to remove the seven 4.5mm screws. There are 2 on the left There are 2 on the right
    • Use a Phillips #00 screwdriver to remove the seven 4.5mm screws.
    • There are 2 on the left
    • There are 2 on the right
    • There are 3 on the bottom
  4. Firmly grasp and pull back casing off. Firmly grasp and pull back casing off. Firmly grasp and pull back casing off.
    • Firmly grasp and pull back casing off.
まとめ
Dustin Rodgers
メンバー登録日: 2010年10月05日
50 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 7-51, Amido Fall 2010 Cal Poly, Team 7-51, Amido Fall 2010人のメンバー
CPSU-AMIDO-F10S7G51
4 メンバー
7のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,396
