メインコンテンツにスキップ
Kodak EasyShare C713 LCD Replacement
必要な工具と部品
  1. Kodak EasyShare C713 LCD Replacement, Batteries: 手順 1、 1の画像 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 LCD Replacement: 手順 2、 1の画像 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 LCD Replacement, Outer Case: 手順 3、 3の画像 1 Kodak EasyShare C713 LCD Replacement, Outer Case: 手順 3、 3の画像 2 Kodak EasyShare C713 LCD Replacement, Outer Case: 手順 3、 3の画像 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 LCD Replacement: 手順 4、 3の画像 1 Kodak EasyShare C713 LCD Replacement: 手順 4、 3の画像 2 Kodak EasyShare C713 LCD Replacement: 手順 4、 3の画像 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 LCD Replacement, LCD: 手順 5、 1の画像 1
    • The LCD screen is hinged at the bottom.
    • Put your thumb in the upper right corner of the LCD screen.
    • Pull the LCD screen out of its outer case with your thumb.
  6. Kodak EasyShare C713 LCD Replacement: 手順 6、 1の画像 1
    • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
  7. Kodak EasyShare C713 LCD Replacement: 手順 7、 2の画像 1 Kodak EasyShare C713 LCD Replacement: 手順 7、 2の画像 2
    • Desolder the two points.
    • One on the port side.
    • One on the bottom.
  8. Kodak EasyShare C713 LCD Replacement: 手順 8、 1の画像 1
    • After desoldering the LCD casing, just use your fingers to carefully remove it.
  9. Kodak EasyShare C713 LCD Replacement: 手順 9、 1の画像 1
    • Flip up the black tab on the bottom of the LCD screen with a fingertip.
  10. Kodak EasyShare C713 LCD Replacement: 手順 10、 1の画像 1
    • Remove the LCD ribbon cable from inside the black tab.
終わりに
6 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Taggart Ashby
メンバー登録日: 04/15/10
354 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 26-19, Regan Spring 2010 Cal Poly, Team 26-19, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S26G19
4 メンバー
14のガイドは作成済み
2 件のコメント
Thank you... i fixed my old camera lcd.
anthoxman - 返信
hvor kan jeg kjøpe LCD skjermen til dette kamerat, og hva koster et sånn LCD-skjerm
fancy tassen - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 23
今までの合計 5,465
