この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Replacing the camera buttons.
必要な工具と部品
Use your finger tip to slide battery cover door away from the center of the camera.
The battery door should spring open.
If this does not happen, gently open the door lifting from the outer bottom side of the camera.
Remove the seven screws from the outer case with a Phillips #00.
All screws are 4.45mm.
There are 2 screws on the port side.
There are 2 screws on starboard side.
There are 3 screws on the bottom.
ある他の人がこのガイドを完成しました。
