この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will show you how to remove and replace the memory card.
必要な工具と部品
First, access the slide door on the bottom left corner of the camera. To open, push down and to the left.
The memory card slot is located just below the batteries.
To insert the memory card, make sure the writing is facing the batteries, and the cut off corner is at the top right. Put the card into the slot and push until you hear a click.
You do not need to remove the batteries to insert the memory card.
To remove, push the memory card until you feel a click. The card should pop out.
2 件のコメント
Hi. I purchased a new memory card. When inserted into the camera, I can’t take a picture because the camera states internal memory full. What do I do??
Bought a new memory card. Cannot take pictures because the screen states "internal memory full”. What do I do?
