メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide will show you how to remove the internal lens of your camera.
パーツ
パーツは指定されていません。
  1. To start, remove the Philips #00 4.5 mm screws on both sides of the camera. On the bottom, there are three Philips #00 4.5 mm screws.  Two are for the front panel and one is for the back panel.  To remove the back panel, take out the screws indicated in the final picture of the sequence. On the bottom, there are three Philips #00 4.5 mm screws.  Two are for the front panel and one is for the back panel.  To remove the back panel, take out the screws indicated in the final picture of the sequence.
    • To start, remove the Philips #00 4.5 mm screws on both sides of the camera.
    • On the bottom, there are three Philips #00 4.5 mm screws. Two are for the front panel and one is for the back panel. To remove the back panel, take out the screws indicated in the final picture of the sequence.
  2. Once all the screws are out, remove the back panel. The front panel does not need to be removed for replacing the LCD or the Lens. To do this, start by removing the bottom of the panel.
    • Once all the screws are out, remove the back panel.
    • The front panel does not need to be removed for replacing the LCD or the Lens.
    • To do this, start by removing the bottom of the panel.
  3. Once the bottom part is unhooked, unhook the top, and the whole panel should come off. Be sure to gently pry the cover off.
    • Once the bottom part is unhooked, unhook the top, and the whole panel should come off.
    • Be sure to gently pry the cover off.
  4. In the top right hand corner of the inside of the camera, there is a Philips #00 4 mm screw that needs to be removed.
    • In the top right hand corner of the inside of the camera, there is a Philips #00 4 mm screw that needs to be removed.
  5. The Essential Toolkit
    コンパクト版iFixitキットの中で最も利便性の高いツール
    ショップを見る
    ショップを見る
  6. The next step is to remove the white ribbon on the upper right hand corner next to the LCD screen. This can be done with or without tweezers. The screen is still attached at the bottom, so do not take the screen off yet.
    • The next step is to remove the white ribbon on the upper right hand corner next to the LCD screen.
    • This can be done with or without tweezers.
    • The screen is still attached at the bottom, so do not take the screen off yet.
  7. Carefully pry the top portion of the screen from the camera. The screen is still attached to the camera via a yellow ribbon at the bottom of the camera. The screen is still attached to the camera via a yellow ribbon at the bottom of the camera.
    • Carefully pry the top portion of the screen from the camera.
    • The screen is still attached to the camera via a yellow ribbon at the bottom of the camera.
  8. To remove the screen completely, push down on the rectangular tab indicated in the picture. To remove the screen completely, push down on the rectangular tab indicated in the picture. To remove the screen completely, push down on the rectangular tab indicated in the picture.
    • To remove the screen completely, push down on the rectangular tab indicated in the picture.
  9. The LCD screen is now completely removed from the rest of the camera. The LCD screen is now completely removed from the rest of the camera.
    • The LCD screen is now completely removed from the rest of the camera.
  10. Now that the LCD screen as been completely removed, the internal lens can be removed. To do this, flip the two black tabs to the left of the yellow motherboard up. To do this, flip the two black tabs to the left of the yellow motherboard up.
    • Now that the LCD screen as been completely removed, the internal lens can be removed.
    • To do this, flip the two black tabs to the left of the yellow motherboard up.
  11. Once the tabs have been flipped, pull the orange tab out. Next, use the #00 Philips head screwdriver to remove the five 4.5 mm screws to the left of the motherboard.
    • Once the tabs have been flipped, pull the orange tab out.
    • Next, use the #00 Philips head screwdriver to remove the five 4.5 mm screws to the left of the motherboard.
    • Remove the three Philips #00 3 mm screws on the silver metal plate directly behind the lens.
  12. Remove the internal lens from the camera. The second picture shows what the camera should look like with out the internal lens attached.
    • Remove the internal lens from the camera.
    • The second picture shows what the camera should look like with out the internal lens attached.
終わりに
2 の人々がこのガイドを完成させました。
Alyssa
メンバー登録日: 2012年04月12日
69 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 6-22, Amido Spring 2012 Cal Poly, Team 6-22, Amido Spring 2012人のメンバー
CPSU-AMIDO-S12S6G22
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 19
今までの合計 4,880
