メインコンテンツにスキップ
KitchenAid Professional 600 Gear Housing Cover Replacement
必要な工具と部品
  1. KitchenAid Professional 600 Gear Housing Cover Replacement, Top Cover: 手順 1、 1の画像 1
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
  2. KitchenAid Professional 600 Gear Housing Cover Replacement: 手順 2、 1の画像 1
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Gear Housing Cover Replacement: 手順 3、 1の画像 1
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
  4. KitchenAid Professional 600 Gear Housing Cover Replacement, Gear Housing Cover: 手順 4、 1の画像 1
    • Remove the 4 Phillips #2 screws connecting the black housing cover to the device.
    • Only one of the screws is seen in the picture. The other three are also located around the black housing cover.
  5. KitchenAid Professional 600 Gear Housing Cover Replacement: 手順 5、 1の画像 1
    • Take off the black housing cover.
終わりに
作成者
1人の作成者と共同作成されました。
Luke
メンバー登録日: 04/11/16
1,380 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 25-4, Maness Spring 2016 Cal Poly, Team 25-4, Maness Spring 2016人のメンバー
CPSU-MANESS-S16S25G4
4 メンバー
18のガイドは作成済み
コメント 1 件
I find your instructions very helpful but one of my housing pins have broken off, Can it be replaced or do I need to replace the housing? If so where do I find the housing part. I can not find it.
w.gupton - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 24
今までの合計 3,117
