メインコンテンツにスキップ
KitchenAid Professional 600 Drive Motor Replacement
必要な工具と部品
  1. KitchenAid Professional 600 Drive Motor Replacement, Top Cover: 手順 1、 1の画像 1
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
  2. KitchenAid Professional 600 Drive Motor Replacement: 手順 2、 1の画像 1
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Drive Motor Replacement: 手順 3、 1の画像 1
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
  4. KitchenAid Professional 600 Drive Motor Replacement, Speed Selector: 手順 4、 1の画像 1
    • Locate the selector switch.
    • Remove the two Phillips #2 screws holding the selector switch in place.
  5. KitchenAid Professional 600 Drive Motor Replacement: 手順 5、 3の画像 1 KitchenAid Professional 600 Drive Motor Replacement: 手順 5、 3の画像 2 KitchenAid Professional 600 Drive Motor Replacement: 手順 5、 3の画像 3
    • Unplug the cords attached the drive motor to the switch.
    • We suggest numbering them left from right so they are reattached to the replacement part in the right order.
  6. KitchenAid Professional 600 Drive Motor Replacement: 手順 6、 1の画像 1
    • Pull out the Selector Switch.
  7. KitchenAid Professional 600 Drive Motor Replacement, Drive Motor: 手順 7、 1の画像 1
    • Remove the two Phillips #2 screws holding the motor in place, located near the fan at the back of the motor.
    • The picture only shows one of the screws. The other screw is located on the exact opposite side of the motor.
  8. KitchenAid Professional 600 Drive Motor Replacement: 手順 8、 1の画像 1
    • Pull upward to remove the motor.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Tallon Dotinga
メンバー登録日: 04/11/16
487 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 25-4, Maness Spring 2016 Cal Poly, Team 25-4, Maness Spring 2016人のメンバー
CPSU-MANESS-S16S25G4
4 メンバー
18のガイドは作成済み
4 件のコメント
anyone know where I can get the hall effect sensor receiver that is on the motor shaft? Somehow it's missing?
Barclay Berger - 返信
is there not a fusible link in series with the drive motor?
wa1shm - 返信
I accidentally pluged my 110v mixer to 220v. Now, what are the possible parts that i need to change? How can i check if the motor is busted?
hyalmar planta - 返信
Are the motor brushes serviceable on this model mixer and where are they located
Thanks
Gary Bell - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 32
過去 30 日: 140
今までの合計 13,663
