メインコンテンツにスキップ
KitchenAid KUDS01DJSS0 Electronic Control Board Replacement
必要な工具と部品
  1. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement, Electronic Control Board: 手順 1、 3の画像 1 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement, Electronic Control Board: 手順 1、 3の画像 2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement, Electronic Control Board: 手順 1、 3の画像 3
    • Unplug the dishwasher or shut off the house circuit breaker for the dishwasher.
    • To verify that power is disconnected, make sure that the control panel doesn’t light up when you press a control button or the power button.
  2. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 2、 3の画像 1 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 2、 3の画像 2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 2、 3の画像 3
    • Open the dishwasher door.
  3. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 3、 3の画像 1 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 3、 3の画像 2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 3、 3の画像 3
    • Remove the four screws from each side of the dishwasher door (eight screws total).
    • Removing the three screws from each side of the dishwasher (six screws total).
    • Support the outer door panel with one hand as you remove the final two screws at the top of the dishwasher door.
    • There are total of sixteen (16) screws.
  4. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 4、 2の画像 1 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 4、 2の画像 2
    • Use your hands to pull off the outer door panel with the control panel.
  5. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 5、 2の画像 1 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 5、 2の画像 2
    • Disconnect the two white outer wires by pulling them out.
    • The two white connectors have the same size and are close together.
    • Use one hand to hold the control panel while disconnecting the electrical connections from the old board.
  6. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 6、 3の画像 1 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 6、 3の画像 2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 6、 3の画像 3
    • Remove the white rectangular connector that has six colored wires connected to it.
  7. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 7、 2の画像 1 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 7、 2の画像 2
    • Use one hand to hold the control panel while detaching the black connector.
    • The black connector is the main connector to the control board.
  8. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 8、 3の画像 1 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 8、 3の画像 2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 8、 3の画像 3
    • Detach the white and gray ribbon cable attached to the black connector.
  9. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 9、 2の画像 1 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 9、 2の画像 2
    • Use your hands to pull the electronic control board out the mounting slots.
  10. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 10、 2の画像 1 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 10、 2の画像 2
    • Push the new electronic control board into the mounting slots.
    • Slide it to the right to engage the locking tab until you hear a click.
  11. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 11、 2の画像 1 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 11、 2の画像 2
    • Reconnect the black connector wires to the new electronic control board.
  12. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 12、 3の画像 1 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 12、 3の画像 2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 12、 3の画像 3
    • Reconnect the white rectangular connector with six wires to the new electronic control board.
  13. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 13、 3の画像 1 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 13、 3の画像 2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 13、 3の画像 3
    • Reconnect the two white outer connector wires to the new electronic control board.
  14. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 14、 3の画像 1 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 14、 3の画像 2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 14、 3の画像 3
    • Reinstall the outer door panel and control panel on the inner door panel and reattach the user interface control wire harness.
    • Reinstall the sixteen mounting screws.
  15. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 15、 3の画像 1 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 15、 3の画像 2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 手順 15、 3の画像 3
    • Connect the dishwasher and reset the circuit breaker for your house to restore electricity.
    • To verify that power is connected, make sure that the control panel does light up when you press a control button or the power button.
ゴール
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Thuan Trang
メンバー登録日: 01/13/22
345 ポイント
1ガイドが承認済み
チーム
York University, Team S-29, Woodhouse Winter 2022 York University, Team S-29, Woodhouse Winter 2022人のメンバー
YORK-WOODHOUSE-W22SSG29
1 メンバー
2のガイドは作成済み
4 件のコメント
Excellent illustration!!!
KO SAMUEL TAK SHUN - 返信
عمل فنى رائع وجميل وبدقة متناهية
khaliddabnoun - 返信
عمل فنى جميل ورائع وبدقة متناهية
khaliddabnoun - 返信
Excellent how to! However the part attached to purchase doesn’t look like the original control board. Help!
magdelena kormusis - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 40
今までの合計 1,334
