はじめに
Your device power could be malfunctioning because of a faulty speed control plate. Learn how to access it with this guide.
必要な工具と部品
Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
The back cover is now free. Remove it by pulling back and up on the cover.
Using a Phillips #2 screwdriver, remove the two adjustment screws by rotating them counterclockwise.
What is the default measurement for the screws? I didn’t know I had to do this and already messed around with the screws.
Problem was that lever would not stay in off position without finger pressure and motor would run as soon as plugged in. In shifting the lever,I noticed a slight variation in the grey fork gizmo that protrudes above the bottom screw. That screw protruded 9/32”. I tightened it to 6/32’ and lever turns off the motor.
7 の人々がこのガイドを完成させました。
コメント 1 件
Thanks for this, but a quick question, when the mixer is switched off, the metal bar on the back of the speed plate at the bottom, is that supposed to rest on the two prongs that stick out towards the bottom of the inside of the mixer? Thanks.
