メインコンテンツにスキップ
KitchenAid KSM150PSER Carbon Brushes Replacement
必要な工具と部品
  1. KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: 手順 1、 2の画像 1 KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: 手順 1、 2の画像 2
    • Using a flat head screwdriver, unscrew the brush cap on each side of the mixer by turning them counter clockwise.
    • Remove brush cap by pulling it toward you.
    • The brushes are held in by springs and will fly out if removed too fast.
  2. KitchenAid KSM150PSER Carbon Brushes Replacement: 手順 2、 1の画像 1
    • Remove brush by pulling it toward you.
    • One corner of the brush is flattened. You can check which way the brush is oriented by shining a flashlight inside the hole.
終わりに
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Hayley Young
メンバー登録日: 12/03/16
211 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S2-G5, Livingston Winter 2018 Cal Poly, Team S2-G5, Livingston Winter 2018人のメンバー
CPSU-LIVINGSTON-W18S2G5
4 メンバー
10のガイドは作成済み
コメント 1 件
I’ve been procrastinating on trying to fix my KA mixer on my own…today I did it. The directions were pretty clear and the only thing wrong was that when I had previously cleaned my mixer, I put the carbon brushes in the wrong way. Once I shined a flashlight into the hole I could see where the notched corner went.
Amber Reimer - 返信
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 78
過去 30 日: 321
今までの合計 13,419
